Filling the gas tank without the pump shutting off?
Everytime I go to put gas in my truck, it acts like it is full of gas and the pump shuts off. It takes ten minutes to put a few gallons of gas in my truck.
Remove the filler neck hose from the fitting where it attaches to the fuel tank. Look inside the opening for the fuel tank, about 3 inches down there will be a mesh screen. Remove the debris from this and you should be good to go after you reassemble everything. Watch out for spiders in here.
+ make sure the vent to the filler neck is not clogged either.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 332
