Clothes dryer repair and support guides.
871 Questions View all
dryer wont stay hot or now get hot
I've taken the dryer apart to see whats going on. This is what Ive noticed. The flame does cycle on and off, repeatably, But when it lights a flame, it only stays light for a bout 30 seconds and clicks off for 2 mins then back on for another 30 seconds and so on. I've cleaned the ducts and all inside the dryer. When put back together, it seem to getting hot at first, so i tried a load, then nothing again, i dont' feel any heat again. What part do you think it is?
Score -1
Add a comment
1 Answer
Chosen Solution
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Score 1
Add a comment
Add your answer
tbelcherztech will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 143
