Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Questions View all
Why is my device not charging?
I recently purchased an iPhone 4 that has had water damage. After having a friend who repairs all sorts of apple products look at it, he though just the battery need replaced due to the corrosion on the terminals. After ordering and replacing the battery i plugged phone in to iTunes and factory reset it. Shortly after i noticed the phone was not taking a charge, although it was plugged in and the device recognized that. Thinking i had a faulty battery i replaced it a second time and had the same results. The device syncs and transfers data just like any other iPhone would just doesn't charge. I have even tried multiple transfer cables, different computers and different wall outlets. No luck. both the dock water damage indicator and the one inside on the lower half (beside battery connector cable) have turned red. I am wondering if replacing the dock connector on the phone will solve my problem, or if my phone is shot. I cant see it being much more because everything works like it is supposed to other than it doesn't charge.
Score -1
Add a comment
Chosen Solution
trevor, the very first thing that you should do is to properly clean your board. If you have "due to the corrosion on the terminals" you will also have it somewhere else. Use this guide to clean your phone. It was written for a 3G but all the points are still pertinent to your phone. While you clean it, check your board for any missing, or burned components. You'll need a magnifying source for that:-) After that, replace the dock connector. There are plenty of other reasons while your phone may not charge, all of them are no fun. There are plenty of components that regulate the charging function, starting with the PMIC, and none are easy fixes. Hope this helps, good luck.
Score 1
Add a comment
Hey mate,
You will most likely have to replace the dock connector. You can purchase them for relatively cheap (around 15 dollars shipped.) I have done it myself and it is not a particularly difficult replacement - following the guide linked above is a good step as well.
Cheers.
Add a comment
Add your answer
trevor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 211
