Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
581 Questions View all
Broke the welded subowoofer connector
While I was replacing my optical drive by a second hard drive, I unfortunately completely disconnected the subwoofer and left speaker connector, even the little part which was welded to the logic board.
As a result, only my right speaker is functional.
I don't know if I can repair it on my own, as it involve re-welding a component.
Does I have to buy a new subwoofer and/or a new logic board ?
Score -1
2 Comments
Hi, have the same problem
Is it possible just to glue socket to the board and align contacts?
Thanks
by
Hello,
I have the same problem... Did you fixed it?
by
Add a comment
Most Helpful Answer
Mourad, this will depend on your damage. If the traces are damaged it'll be difficult to solder. Any of the soldering to the board should be done with the right tools and the right knowledge. Post an image with your question that shows the damaged pieces for a better answer.
Score 2
Add a comment
It's possible
You can try, but I would recommend a new logic board. However, if you still have 1 functional speaker, why not just keep that? By the way, it's called "solder", not "weld"
Add a comment
Add your answer
Mourad will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 155
