How do I delete the following message?
"The disk you inserted is not readable by this computer".
Npte: No disk was inserted and message prevents computer from being put into "sleep" mode.
You are experiencing disk read/write errors. Boot from your install disk and run disk tools:repair disk. If this procedure fails you'll could possibly need to replace your HD. If you've been inside this box you might have damaged, or left loose a connector or ribbon cable (only you know if that's a possible source of the disk error).
Good Luck,
If this Answer is helpful please remember to return and mark it Accepted.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 83
