Model A1318 / 32 or 64 GB capacity
299 Questions View all
Question Closed
I replaced digitizer and fram now home button not work. why?
My glass broke and went on youtube and then bought new digitizer , got it then realized i needed plastic fram so bought it and took apart and put back together and it turns on but won't go home. the home button doesn't work. did i forget a part. looked on work area and found a little plastic piece that looks like it might go under the button but not sure. is there a site to see a parts diagram?
thanks
mark
1 Comment:
I noticed you never got an answer to this. Are you still having this problem?
by
Add a comment
This happened to me. My problem was a rubber piece that fell off the digitizer assembly after I installed it. This created resistance. To get my home button to work requires holding in the left lower corner then pressing home.
Add a comment
look at the home bouton connector
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,764
