iPhone 3GS missing components
L85_RF AND L3_RF missing please what do I do?
Thanks
Thanks
Jaywn, there is absolutely no reason to replace the board. L85_RF is the "blue inductor" 1.2NH-1.36A-0.045OHM and as you probably already know, some people do bridge it by using a circuitwriter pen or similar tool. L3_RF is another inductor, values7.5NH-1.4A-0.080OHM. I would replace both of these components. They are readily available, but a bit hard to solder to the board due to their size. You'll need good tools and excellent skills. Both of the inductors are part of the cellular antenna circuit, your phone will not have any service without them. Total cost for both pieces should be less than $5.00, hope this helps,
Thank you. Do you know where I can find these parts?
It depends on where you are located. I would start with mouser .com or digikey.com. Thank you for accepting my answer.
If the phone works, do nothing. If it does not work, replace the logic board.
Hi. It just searches. Where can I find the L85_RF component or can I just bridge across?
Thanks
http://forum.gsmhosting.com/vbb/f631/3gs...
Here its the solution!
Same as in the original answer
Yes, is possible in Mouser-DigiKey,etc. Cost about £ 0.010 the spares and £ 15 for shipping + VAT.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 319
