Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
Why not able to format/partition SSD?
i bought an Sandisk SSD (UltraPlus-128GB) and replaced my faulty Hard Disk in my MAC-book Pro.
After install, The device is detected in "Disk Utility", but i am unable to format / Partition the disk.
Error :
Partition failed with the error:
"POSIX reports:The operation couldn't be completed. Cannot allocate memory."
Regards,
Mani
Score -1
Add a comment
1 Answer
Chosen Solution
See if there are jumpers on the drive as it may need to be slowed down to be seen.
Score 2
3 Comments:
Thanks for help...No jumper in this drive... Below is the FYR..
http://www.sandisk.sg/products/ssd/sata/...
any other suggestion ?
by
Yes, it's getting hard finding SSD's that work with SATA I or SATA II interfaces. Many are only able to work with SATA III now (newest models)
by
The SanDisk Ultra Plus Solid State Drive is compatible with SATA Revision 3.0 (6Gb/s) interfaces and is backwards compatible with SATA Revision 2.0 (3Gb/s) and SATA Revision 1.0 (1.5GB/s) interfaces. I
Try replacing the hard drive cable. These cables have become my most common repair. I now keep two each of the 13" & 15" cables in stock. http://www.ifixit.com/MacBook-Parts/MacB...
by
Add a comment
Add your answer
manivannan sozhan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,161
