Model A1138 / 1440x960 screen resolution
100 Questions View all
Trackpad doesn't work correctly
I bought an used PB for my son.
The trackpad pushbutton doesn't work that good. It doesn't "click" like I use to know it from mine. Often I have to press
the pushbutton more than one time. It is not aout of order, but it could be much better.
What can I do?
Thank you!
regards from Germany
George
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
Hi. The only repair for the trackpad I know of is to replace the top case as it is built in. I'm including the teardown and part number for this repair. If it were me however I would just buy a USB mouse and use that. ( A whole lot less money) Ralph
PowerBook G4 Aluminum 15" 1.67 GHz Upper Case Replacement
G4 Aluminum 15" 1.67 GHz (HR) Upper Case
Add a comment
Most Helpful Answer
Sounds like you may have gotten something in the side or under the pad. Take a thin stiff piece of plastic and run it around the pad to see if you can dislodge anything.
Score 2
Add a comment
Add your answer
George will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 836
