Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
phone got wet and wont turn on?
so ive lay my wifes iphone face down on a very small puddle of spilt tea while charging, i realised straight away so picked the phone up and wiped it dry. it seemed to be ok for a couple mins then just kind of died. so ive dried the phone out for aroud four days but my thoughts are its to late. ive tested the battery and its ok, also tested the mother board wich is also functioning perfect. so anyone got any ideas what could be wrong? my suspicions are the wet got in the top end of the phone as i can see some evidence near the top in the inside but again its not alot.
thanks in advance
Score -1
3 Comments
How did you check the motherboard as well as the battery?
by
hi i stripped the phone down to dry it out and used my own iphone to test the parts, ive done a few scren changes in the past so i knew what i was doing. while her mother board and battery were in my phone i conected to itunes done a back up of her data and retored the iphone incase i cant fix it and have to sell it on
by
If the battery as well as the logic board functions in another set up, I would suggest to take a good look at the power flex and connectors. You definitely want to check for corrosion as well as other damage.
by
Add a comment
Chosen Solution
Remove the battery immediately and try to clean off any corrosion from the logic board, you'll probably need to replace the battery too.
Add a comment
I wouid see if iTunes can detect it. If it does would do a bit of harm to try a new screen.
1 Comment:
hi thanks for your responce, ive tried a few times conecting to itunes but no luck there.
by
Add a comment
Add your answer
martin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 187
