phone got wet and wont turn on?
so ive lay my wifes iphone face down on a very small puddle of spilt tea while charging, i realised straight away so picked the phone up and wiped it dry. it seemed to be ok for a couple mins then just kind of died. so ive dried the phone out for aroud four days but my thoughts are its to late. ive tested the battery and its ok, also tested the mother board wich is also functioning perfect. so anyone got any ideas what could be wrong? my suspicions are the wet got in the top end of the phone as i can see some evidence near the top in the inside but again its not alot.
thanks in advance
3 Comments
How did you check the motherboard as well as the battery?
by oldturkey03
hi i stripped the phone down to dry it out and used my own iphone to test the parts, ive done a few scren changes in the past so i knew what i was doing. while her mother board and battery were in my phone i conected to itunes done a back up of her data and retored the iphone incase i cant fix it and have to sell it on
by martin
If the battery as well as the logic board functions in another set up, I would suggest to take a good look at the power flex and connectors. You definitely want to check for corrosion as well as other damage.
by oldturkey03
