Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Why is my MacBook Pro charging at a trickle level?
Ok, here is the story:
Day 1. I spill a full glass of water on top of my **closed**, powered-down, but plugged-in macbook. I have a case on it, but I'm sure it trickled down into the DC-in board and it pooled around the bottom of the macbook.
I quickly unplugged and dried the thing. I put it on rice, and set up a small space-heater about 4 feet away to blow warm air on it.
Day 2. I try to turn it on (24 hours after spill). No luck. Continue to dry it by opening the bottom up, and setting it up like an air tunnel, blowing continuous warm air on it.
Day 3. 48 hours - the must be dry as a bone. Still will not turn on. I plug in the charger to see what happens - and I see a breif flashing amber, then nothing.
Day 4. I take it to Apple. They hear me say 'water damage' and they say '450 bucks'... but we'll look at it for a second. The girl does a quick SMC reset, plugs it in, light goes green, and it turns on!
Day 5. I notice that my charger cable has actually been dim green all along - never bright green. (hence, trickle charge).
I order a DC-in from ifixit, I install it (I feel good about that process). But still, we're at a trickle charge.
I also soaked and dried the previous DC-in with alcohol, and tested that. And I soaked and cleaned my logic board some. There seems to be some black 'charring' on the teeth of a connector just above the DC-in board.
Is there any solution besides a new logic board? Should I clean it more thoroughly?
[OH, also. I've troubleshooted the charger... it works on other computers fine.. and working adapters show the same dim green light on my computer. ]
Thanks for your help!
Keith
Score 1
Add a comment
Chosen Solution
Dim green light means that the charger (AC adapter) doesn't adequately communicate with the SMC (main power circuitry). A shorted top case (and/or other internal damaged components) could cause this situation. Disconnect the AC adapter from the machine, disconnect the battery, unplug the top case from the logic board, connect the AC adapter to the magsafe port and check if you get a normal green led on the magsafe tip.
Score 2
8 Comments:
Thanks lemerise - I will try this. By 'remove the top case' - can I assume what you mean is removing the logicboard and dc-in board, and trying to plugging in the mag-safe without those components being connected to the rest of the MBP body?
by
no...I did no say "remove the top case". Just disconnect the top case from the logic board and plug the AC adapter to the MBP. It's a troubleshooting step to check if the top case circuitry is faulty then modifying the input voltage to the SMC. I often worked on liquid spilled machines that had wrong voltage on the G3Hot power pad (normal voltage is 3.42V) until the top case was disconnected from the logic board. You then know that the top case is shorted.
by
Ah ok, I understand... however, in order to 'disconnect the top case" - I'm uncertain which connection(s) I need to unplug... all of them? Or is there a single connection that would be shorted.. Thanks for your help!
by
large ribbon cable near the battery connector.
by
ok, I disconnected the top case via the large ribbon cable... checked the magsafe tip - still dim green. I proceeded to disconnect EVERYTHING from the logic board except the DC-in... and still, dim green when i plugged in the magsafe.
Does this just mean my top case is not shorted.. but that something on my logic board may be?
by
Show 3 more comments
Add a comment
It is usually the DC-input board. These go bad almost instantly and are made to pop during a water spill situation to filter out dirty power. kind of a fail safe. You can get chinese replacements on ebay that seem to work fine for under ten dollars shipped, and OEM ones are about 30 bucks.
Too many logic board replacements have happened instead of just fixing this input. There are voltages you can test for to see if it is the magafe
1 Comment:
Chrsitopher Hazard, it looks like that was already taken care off "I replaced the DC-in board with a brand new one"
by
Add a comment
Add your answer
kgkola will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 8
All Time: 1,424
