13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
Question Closed
display issue, shadow on right side
Greetings,
I recently purchased a Late 2008 Aluminum Macbook - MB467LL/A - MacBook5,1 - A1278, to repair and use for myself. The display has an issue that I would like some advice on. When the macbook boots up, the left side of the screen is the normal bright white color, but a portion on the right side of the display is very dim/dark, like a shadow. Then in about 10 secs or so the right side lights up, normal and everything looks perfect. When using the macbook the screen has no issues, it displays correctly. If the computer screen, dims or powers down when I havent touched the keyboard in a while, when I reactivate the macbook, the dim right side is back again, for the same 10-15 secs before, returning to the normal expected display. I have provided a link to a few images of what I am experiencing. If anyone knows the problem and a possible fix, I would appreciate any advice.
http://forums.macrumors.com/showthread.p...
Thanks,
Chris
2 Comments
Try it with an external display? If the external does the same thing - bad news- you need a new logic board. If the external behaves fine the problem is in the internal display chain... possibly a cable (because it is intermittent).
by
I tested the Macbook on an external monitor and the shadow problem does not appear. So at this point you feel the issue lies in the intenal display chain. How would I go about finding and fixing this problem. Thank you so much for your help, I appreciate it.
Chris
by
Add a comment
1 Answer
Chosen Solution
I think you'll have to use the Guide to open it and inspect the board and LCD connectors for corrosion. If something was spilled into it and only some of the connectors are corroded, giving extra resistance, once there's some heat and electrons flowing the difference in resistance settles down. MAYBE a good cleaning of corroded contact will solve the problem and you won't have to replace any parts.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,157
