Replaced HD Now computer will not power on
iMac Intel 21.5 EMC 2308
Replaced dead HD, with compatible; 1.0TB Seagate Barracuda 3.5 inch, SATA 6.0Gb/s, 7200RPM internal hard drive. Now the imac will not power on.
Apple use a proprietary hard drive with special heat sensors on this machine. Here are some drives that WILL work: http://eshop.macsales.com/shop/hard-driv...
The new Hard Drive I installed was the following:
1.0TB Seagate Barracuda 3.5 inch, SATA 6.0Gb-s, 7200RPM internal hard drive. 2 Y Qty: 1 $89.99
Is this a compliant hard drive to use? Or must I order a different one and replace once again? If I need to replace, please send me a link with the exact Hard Drive I will need. Thank You once again.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 227
1 Comment
The new Hard Drive I installed was the following: 1.0TB Seagate Barracuda 3.5 inch, SATA 6.0Gb-s, 7200RPM internal hard drive. 2 Y Qty: 1 $89.99 Is this a compliant hard drive to use? Or must I order a different one and replace once again? If I need to replace, please send me a link with the exact Hard Drive I will need. Thank You once again.
by paul
