The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
197 Questions View all
Question Closed
No boot, No display, no signal and white power light flashes once
Hi..
hope you can help out as you have been refered and have good reviews.
Have a Powermac A1047, EMC no. 1969
G5 2.0 gh dual processor machine that doesnt boot, display is black, no signal and white power light flashes once every 5 seconds. Also there is a red light on the main board that you can see through the front grill.
Checked battery and has 3.6 volts, reseated vcard and ram, have 2, 256meg modules in slot 2 on each bank.
Do you need a hard drive to be connected to get this to boot or grey screen?
Thanks,
Add a comment
Chosen Solution
Could be loose, missing, wrong RAM. So if you changed the RAM put back the original. If you haven't changed the RAM inspect it for damage and check that it is "clicked" in.
The # and position of the RED LED is important to diagnosing what it means.
LED 1—CPU A:
LED 2—Overtemp:
LED 3—Power On: red—the main power is on
LED 4—Trickle: yellow—Power Mac G5 is plugged into the wall correctly
LED 5—Open Firmware good: green—no problem
LED 6—CPU B:
LED 7—Checkstop:
IF the Red LED you see is not #3 then you have CPU/Logic Board problems and as a DIY solution replacement is the preferred method of choice (Adding/removing/repairing Logic Board components are not really DIY projects-they require special tools, materials and experience).
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
I've just had the same thing happen to my G5 1.8 with 2GB ram. Installed new battery which wasn't the problem then removed some ram(left 512mb in top slot of top two and 512mb ram in bottom of bottom two slots. Machine booted,now backing up while i have the chance as the fans are pretty noisy, the future is uncertain but the plus side is i just got a 2nd chance to save some irreplaceable stuff.
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 2,535
