2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Question Closed
Display with verticale strips in colour?
MacBook Pro 15" 2.4 GHz Core 2 Duo Model A1260
My MacBook shows verticale strips in blocks of pink and white at the sides and a block of green and black in the middle. And I can turn it on and off but that is it. No, other reaction.
Is the logic board defect? Or what else could it be?
Help would be great.
Thanks
Lius
Add a comment
Chosen Solution
Try hooking the computer to a external monitor to determine if the problem is in the logic board or the display or its cables. Link provided to previous question to explain the process. Good luck.
Why my LCD screen has a single vertical pink line?
Score 2
1 Comment:
Thanks for the answer.
I tried it twice but there is nothing on the other monitors.
So now I know it is not the monitor but the logic board, or ?
by
Add a comment
The A1260 model had recallable problems with the nVidia 8600 graphic processor (now expired), but you should be getting the same thing on the external monitor. Please check your external monitor hook up. Also please give us the last three figures of your serial number so we can make sure of which GPU you have. This issue is very well documented on this site.
Score 2
1 Comment:
I have same issue on my mac mini, it shows me pink strips until booting and then restarts. Its unbootable.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 200
