The Nexus S is a smartphone co-developed by Google and Samsung was the first smartphone to use the Android 2.3 "Gingerbread" operating system.
28 Questions View all
Question Closed
bad contact micro-usb charger attack
looking the micro welds they seems to be all right but they doesn't work...is it possible to weld againg them or it's necessary to change all the part of mother board where the chargar attack is attached?
Add a comment
1 Answer
Most Helpful Answer
Kevin Santi, yes you can reflow the existing solder with a small soldering iron. Test your jack with a multimeter. Plug it in and test on the motherboard contacts, to make sure that you have power on that end. Hope this helps, good luck
Score 1
1 Comment:
Thank you very much =D
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 427
