Power light not working after dual hard drive kit installed
I went through the process of installing the dual drive kit. Everything worked fine, with the exception that the power LED is longer working. When I first re-assembled the light was permanently on, the second time it is permanently off.
Can anyone enlighten me as to what I am missing?
Thanks!
Robin.
2 Comments
I replaced the IR cable, as it was damaged. The cable is also used for the power light. It's all working fine now.
by rwalkerphl
Same thing happened to me!
When I was assembling it back, I noticed there was a connector under the fan that was not being used, but saw no cables to attach to it. Could that be it? Or could the IR sensor be loose? I did not test the remote control. Everything else is working fine on mine, Bluetooth, Wi-fi, etc.
by marcelotmelo
