Everything you need to repair your iPhone yourself! From the newest iPhone 15 lineup, all the way back to the original iPhone 2G released in 2007, iFixit has free repair guides and disassembly information for every single iPhone, as well as the best replacement parts, tools, and tips in the galaxy.
36501 Questions View all
Question Closed
Mic wont work after receiving water damage, Dock faile
The iPhone gets above water, is do work well everywhere but the microphone does not.
Changed the Mic and 'still does not work.
I wonder if it may be damaged the motherboard or is there any solution
Add a comment
1 Answer
Chosen Solution
Yes when you put a powered logic board in water it will get damaged. Especially if you put power to it before it's had adequate time (days not minutes or hours) to dry.
You can use the tags at the left to find a guide and advice about troubleshooting your problem, but if you've replaced the microphone a damaged connector or component on the logic board is the next most likely cause to your problem. Logic board component repair IS NOT A DIY PROJECT. . . however complete replacement of the logic board is.
Good Luck,
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 2,239
