MacBook Air 13" 1466 Lcd Backlight issue
Hi there,
i have i big problem. I let fall a bottle af tea over my macbook air 13" mid 2012.. After them the MBA goes dark.. Everything working well but the display is dark. I can see under bright light the whole screen.. I can use the mouse, trackpad, WIFI, Bluetooth and i can se ma screen but everything is very dark...
If i connect it to a external monitor everything working well so that the grafic card cant be damaged.
I think its the inverter Board or inverter converter on the logic board or something like this. I think the LCD have no problem.. Where is the location of inverter board on MBA 1466? is this integrated on the LCD Panel so that i replace the comlete LCD panel or is this like the MB pro 2010 only a inverter board that can be replaced with new one. I try to find inverter for MBA 2012 but i din't find this part anywhere...
Can someone help me the locate the problem or some reasons that can be initiate the problem and finally how can i fix it...
i find this : Linear Technology LT3957 inverting converter
for one possible reason..
But where is the inverter board on this mba...
Which other causes can be initiate this failure?
thank you for a little inspiration to find the right way.
