Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Question Closed
Why my iPhone wifi is so Weak after fix volume button?
hi my friends i have problem
i fix my volume button and after that my wifi is so weak !!
i read in some forum that in iPhone is metal on near the long Screw in top of phone that may fail and Repairman forget plug this ?? is this possible ? or problem is from my wifi antenna ??? please help me !
Add a comment
Chosen Solution
If you can take apart the phone yourself, check the connection of the upper antenna cable toward the top right of the device. Wifi signal can be disrupted if this isn't plugged in all the way. It should be under a metal clip and a large screw.
-RhinoShock
2 Comments:
thanks for your help ! if he lost that clip what can i do ?
by
I don't really think the clip has much to do with reception, just if the cable isn't plugged in all the way. Try to re-seat it and see if that helps.
by
Add a comment
To fix, take phone. Sell phone, get any other kind of phone iPhones are for faggots Problem solved, you are welcome
Add a comment
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 4
All Time: 271
