Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Question Closed
Cable removal with spudger (DETAILS)
Your instructions just say to "use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
How exactly do you disconnect the cable with the spudger ? Do I slide the spudger edge underneath the numbered tabs? Do I push something with the spudger??
Please provide more detailed info on exactly how the cables disconnect so that I don't damage them in the process.
Thank you
Add a comment
1 Answer
Chosen Solution
If you move your mouse to the upper left of the photo you will see a word large. Click on that for more detail. I have included the magnified photo for you. It shows the spudger sliding under the connector. Hope this helps. Ralph
http://s1.guide-images.ifixit.com/igi/Pv...
Score 1
1 Comment:
Thank you.. got it...
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,250
