Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
20033 Questions View all
How do I clone a windows drive?
I want to partition a 750gb hard drive on my mac so I can run windows 7 on one partition and mac os on the other. I have a 160gb windows drive that I want to clone and install on my mac.
How do I do that?
Score 1
Add a comment
Chosen Solution
This get tricky as your not really running Windows alone here. If your were you would use a Windows cloning app. Here you can't as these apps go down to the file system block level (true cloning vs imaging).
Look for a Mac app that can do FAT32/NTFS file systems or use a Windows backup or file imaging program and not try to clone.
You could also use a syncing program to copy over to a network volume on to your own file server (or internet backup type of service - iCloud)
1 Comment:
I've used PartImage ( http://en.wikipedia.org/wiki/Partimage ) to great success in the past.
by
Add a comment
Most Helpful Answer
In my shop I use apps by Paragon Software. It will do NTFS/Mac/Linux, from partitioning, cloning drives, backups and even make bootable recovery images of your OS. Worth taking a look.
I would use OS/X install and set it up to dual boot, one partition for OS/X and the other for windows. It should create a small partition for the boot manager so you can select which partition to boot to OS/X or Windows.
Once you have that set up, then use Paragon to image your other drive over to the Windows partition. Note, however, if you pulled that Windows drive from a PC, it may take it some time (if it loads) to find the new drivers, etc, to match the hardware on your mac.
Score 2
Add a comment
Larry -
Don't forget to setup your Windows partition within Apples BootCamp application before installing Windows and your Windows apps & data.
Also, make sure to make a good backup of your current Mac volume before you start altering the partitions.
You may want to think about getting a larger drive to swap out with your current one. Then put your current HD into an external case. This gives you a clean slate to configure your HD for OS-X, BootCamp & Windows with plenty of space for apps & data for both.
Your other option here is using a virtual machine (VM) to run windows in using VMware Fusion or Parallels Desktop. These run within Mac OS-X as such you don't need to create a FAT or NTFS partition instead they create a storage drawer within your current Mac volume to hold your windows apps & data.
Heres a good rundown on the differences Best VM for Mac
Add a comment
Add your answer
larrypierceall will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 7,086
