Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
Question Closed
Is Seagate Momentus XT compatible with my MBP?
MacBook Pro 13 2522 Unibody Mid 2010
Hello,
I bought the hdd Momentus XT 750gb, hybrid drive, put it into external drive case (USB), formated it, created one partition, used carbon copy cloner to create a clone from the original hdd. Then restarted MBP by using external drive for booting as a test. All worked fine, but after replacing old hdd with the clone, MBP couldn't detect the new hdd/clone, i.e a folder image with questionmark inside was shown on the display. Do you have any idea how t fix it? There was one hint from apple forum to replace the SATA cable. What do you recomend?
Best Regards
Pawel
Add a comment
1 Answer
Chosen Solution
Check your 2522 number.
Your new hard drive is probably to fast, it's 6 GB.
The original drive was a 3GB.
Here's how to set it by using he jumpers: http://knowledge.seagate.com/articles/en...
Score 2
2 Comments:
BTW: I installed a 500GB Seagate XT into a 2012 MBP today with no issues.
by
Than you. I'll try it and let you knwo if it worked
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 6
All Time: 1,737
