Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Component Identity required please!
Is it necessary?What does it do?Where can i order it?Are you sure it's a connector?Because the connector seems to be the one on the right.I want to know more about that golden one, where i could buy one?
1 Comment
Yes, the brass one is a connector....;-)
by
Add a comment
Chosen Solution
john they are available at places like this as well as places like this. I believe the manufacturer is murata and the part number is MM4829-2702. The datasheet is available right here. Hope this helps.
Score 2
Add a comment
This is a antenna . By this you phone connected with Network. this component is necessary for a working phone. without this phone will not connect to carrier. it will stay in no service or searching .
Score 1
2 Comments:
I have a second hand Iphone and this component is missing and the blue inductor is also missing.The phone is always searching with no service.Where I could buy or order these two components?
by
You can remove these from any non working phone .
by
Add a comment
Add your answer
John will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 343
