Released in 2010, the Flip Mino HD is a pocket-sized camcorder with 4 GB and one hour of shooting capacity.
25 Questions View all
Where can I find a replacement screen for Flip minoHD?
The screen on my MinoHD was damaged. The Flip Video support folks tell me my only option is to toss it. I'm unwilling to accept that without first trying to fix it. Where can I buy a replacement screen for the camera?
Thanks,
Bob
Score -1
1 Comment
Is it under warranty?
by
Add a comment
Chosen Solution
These cameras are effectively priced to be disposable, parts are nearly impossible to find. What I would do is find a parts camera on a site like eBay with a good LCD and transplant that into your camera.
Cisco doesn't sell parts and replaces the entire camera, so it's likely they just recycle them once they get yours. The problem is the parts cost often exceeds the value of the camera and it doesn't make sense to repair them or stock parts.
Score 3
Add a comment
As Nick said, check eBay. You can probably find one that has other defects otherwise and take the screen from there. Once you have the extra Mino, use the teardown to remove the screen and install it on yours.
Score 1
Add a comment
I know the non hd version uses the same lcd as the iPod nano 2g but im not sure about the hd, you can just google the part number (located under the ribbon) and im sure you can find a replacement
Add a comment
hello i had a bad lcd in minohd 120 min , and replace it with a display from flip ultra standard U1120 , is the same part , i search for the part number and i couldn't find anything , right not i am going to get an lcd as Jakob DylanG sad for ipod nano and see if it work , thanks and i hope it help somebody else
1 Comment:
hey, yuberth
did the ipod nano 2g lcd screen work for the ultra hd flip camera?
by
Add a comment
finally i change it with the display from another flip a 60min not hd the use the same , but I check the replace for ipod nano and contact board part is shorter that the one for flip screen itself looks the same but I never try it.
Add a comment
Add your answer
Bob Flynn will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 14
All Time: 6,277
