2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Question Closed
right fan not working
for how long can i run my computer (MacBook Pro 15" 2.4 GHz Intel Core 2 Duo) with only one fan if i disconnect the noisy one and use the computer for just couple of days before fixing it (i'm presently far away from tech support)?
Add a comment
1 Answer
Chosen Solution
Unquantifiable. Depends upon your ambient environment, your tasks & other variables. Clean off all the dust inside, try and use a laptop cooler, give it plenty of "help" cooling by allowing air passage around the CPU (if possible leave the top case loose & propped open, if the environment is not dusty, point a small fan its direction) - use an external USB keyboard/mouse if you choose to do this.
You could try using a fan app to run the other fan at maximum (it might do this on its own).
If this answer was helpful please remember to mark it accepted.''
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 362
