Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Home Button not the same after successful battery install...
After installing a battery in my iPhone 3G, my home button takes a bit more pressure to work? Everything works fine- I went and purchased a can of compressed air and re dissembled the cover and tried to clean out the backside of where the button is, but it’s still not as easy to press before I dissembled the first time. I did notice there are contacts where the button on the backside contacts the logic board (I think it’s the logic board)… My question is, should I try cleaning the “points” with a Q tip and distilled water? Any other ideas? Thanks in advance.
Score -1
Add a comment
1 Answer
Chosen Solution
You could certainly try that- it could also be that the front is just not quite clicked into place the whole way.
Score 2
1 Comment:
Solved!!! That was it, I pressed a bit harder right around the home button and it clicked just a tiny bit- good to go... Thanks for the reply!!!
by
Add a comment
Add your answer
diggity will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,341
