Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
Display trouble (vertical lines)
We own a 2008 20" Intel iMac (model A1224, EMC 2210).
While booting (if the iMac is cold), the display looks normal for a few seconds, then turns to a lot of thin color vertical lines.
A warm reboot immediately gives the vertical lines on the screen.
The video circuitry seems fine, since connecting an external monitor (and using video mirroring) shows the usual desktop on this external display.
Is the problem related to the inverter or the display itself ?
Many thanks in advance for the help.
J. Lejeune
Update
Thanks for the infos.
There is no current Repair Program on Apple Support for this issue.
I will try to get hand on a video cable to replace it, and see if it cures the problem.
This will be the most affordable option, I guess.
The Apple part of the LVDS cable is 922-8197 for this iMac (A1224-Early 2008-MB324LL).
Jo Lejeune
Score 1
3 Comments
Hi
I've got the same problem. So what did you do at the end it may help me.
by
I've ordered the LVDS cable (Ref 922-8197 for our A1224 iMac) but received a wrong model.
I'm still waiting to receive the right one promised by the chosen Apple parts US-based reseller.
I'll keep you informed after having tested it in our faulty iMac.
by
Unfortunately, replacing the LVDS cable didn't solve the issue.
We've decided to give up, the price tag for a new lcd display being unattractive...
by
Add a comment
1 Answer
Chosen Solution
This was/is a "known issue" on that age/model iMac. Go to Apple Support and enter your serial number to see if there is an extended waranty repair available. It could be the inverter, a cable (most likely) or the display (LCD) itself.
If this answer was helpful please remember to mark it accepted.''
Score 3
Add a comment
Add your answer
Jo Lejeune will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 22
All Time: 2,820
