Repair guides for displays (or monitors) for computers or other devices with video output.
505 Questions View all
Changing input port on Asus VE278Q monitor
Accidentally change the input port from HDMI to DisplayPort...
Only have a HDMI port on computer.
Monitor was factory set VGA.
How to set it back to HDMI since I can't access to monitor menu anymore?
My solutions...
DisplayPort to HDMI adapter?
Borrow a Mac with DisplayPort?
Since VGA was factory set, is monitor would recognize a VGA connection as default?
Thanks!
Score 1
Add a comment
Chosen Solution
When the other input ports ( such as VGA or DVI ) have cables plugged in, the monitor will display the signal from these ports. So please unplug all the other input cables. Press input select button to adjust the input port.
Add a comment
Most Helpful Answer
For input select not responding: Power on, press menu and hold. Unplug power till monitor goes off, and then plug monitor back in. The input select will now work again. Worked for my ASUS VE278 just now. I had tried 3 different cable styles and still no signal and menu would not come up either. So I found this solution when searching for getting to the service menu.
Score 2
Add a comment
Add your answer
Marc Gilbert will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 70
All Time: 37,312
