LCD not working Horizontal lines
Hello My 2006 Macbook Pro 2006 one day started with horizontal unreadable lines on screen. Works on another monitor. Not sure if its LCD Bad, Logic board bad, Video cable, video inverter
Any direction as to what problem is would be grateful thanks
Score -1
1 Comment
Thank you for your info I will check cables already checked cable to computer need to check cable to LCD
by
Add a comment
1 Answer
Chosen Solution
If an external monitor works fine you can rule out the VGC and logic board, look into the cables and the LCD screen itself. If the unit was damaged (dropped or screen forced back to far - weak or loose hinges) the display data cable could be cut/nicked or loose. Overheating of the CPU can also sometimes cause this... clean the inside and inspect the video cable.
If this answer was helpful please remember to mark it accepted.
Score 1
Add a comment
Add your answer
Robert Meyers will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 564
