Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2911 Questions View all
Is the glass+digitizer of an 4S equal to those of a 4?
Can I use the glass+digitizer of a iPhone 4 to replace the glass + digitizer of a iPhone 4S.
The LCD is ok and stays in the 4S.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Mario de Deugd, "The LCD and glass -- a carryover from the previous generation -- are fused together, making cracked glass repair more costly" from here. So, if you want to replace the whole display, check these questions Is the display the same for the 4 and 4s? and Do the iPhone 4S and 4 have the same front glass? as well as multiple others. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Mario de Deugd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 246
