The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
Ps3 won't work on hdmi cable. No signal
My ps3 won't work!
It has a hdmi cable but no signal!!
I tried different ports and different cables
But no luck. I also tried holding it down to reset the video settings but still no luck!!
PLEASE HELP I JUST BOUGHT IT LAST WEEK
Score 3
8 Comments
you say diffirent cables, you mean hdmi or also scart?
by
it won't work
by
I have no on or off switch on the back of the ps3
by
try using the compant cablde for the ps3 #the ps2 video cable
and then go to settings - video setting than click the first one than go to the top of the line you should see hdmi and than click x than x again than switch to hdmi
by
Hi I have a PS3 and the HDMI port and AV port both of them do not work they glitch out when I try to plug any of them in and they have like lines and red and green square glitchy things in it what does that mean
by
Show 3 more comments
Add a comment
Chosen Solution
1 make sure tv or monitor is on and change source to proper input IE Hdmi 1 or 2 etc.
2 Ensure your ps3 is off but ready to be turned on. Fat ps3 has switch in back that need to be in on position.
3 hold power button for 5 to 6 seconds and let go after 2nd beep, it should come on with a beep and wait for 2nd beep.
4 this should reset your video, if display flickers then it should come up.
5 if it doesn't, try turning the power off then on again. Repeat steps 2 to 4 if it doesn't work.
If you keep trying and it doesn't work, then your unit might have to be repaired.
Score 5
7 Comments:
Mine does this no video at all
by
Worked great ty I was freaking out for a second..lol
by
Awesome! Thanks
by
What part would need to be replaced?
by
Tried it today and it worked like a charm the first time! Thank you!
by
Show 2 more comments
Add a comment
PS3 80gb super slim it has a black screen and no singal what is wrong with it
Score 1
1 Comment:
Same here ! We'll my 150gb is working find but my 500gb slim that has been in my closet for a couple is doing just this ! I tried multiple cables and tested it with 3 different screens. All no signal
by
Add a comment
Add your answer
Jesse will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 153
All Time: 67,070
