The G4 Quicksilver came in 533MHz, 667MHz, 733MHz, 800MHz, 933MHz, And 1.0GHz speeds.
49 Questions View all
Question Closed
won't connect to internet is it fixable?
Home struck by lightning and computer works but doesn't connect to the internet is it fixable?
Add a comment
Chosen Solution
If the only issue is the Ethernet port or modem is dead you can replace them. The Modem you can replace from MacPro.com for about $30
http://www.mac-pro.com/s.nl;jsessionid=0...
The ethernet port you can install a third party card in one of the slots for about the same. The one I use is a D-Link DFE-530TX+ Card and cost me about $35. But here is one for $15 :
http://www.dlink.com/products/?pid=122
It is Mac OS X Compatible and saves from having to replace mother board. Easy install on both parts.
Good luck
Score 3
Add a comment
Well, your ethernet board could have been fried, that's a common problem.
Unfortunately, the part is hard to find, so chck some of the links mactech posted and also search ebay, amazon, etc.
A workaround is to get a USB to ethernet adapter. You plug this right into a USB port and you have an ethernet port.
Score 1
2 Comments:
I don't think the Quicksilver has USB2 ports. Ralph
by
Good point, but there are some USB 1.0 to ethernet adapters out there. Also, a USB1.0 to 2.0 adapter connected to a USB2.0 to ethernet would work.
by
Add a comment
Y need a new modem but does the computer work???
Add a comment
Yes the computer turns on and you can use and open files on it but you cant connect to the internet. I was told I would maybe need an new ethernet card but need a cheap quick fix. Thanks
1 Comment:
Look at the D-Link one I posted above. It is cheap and all you have to do is order it, load the software and your back up. Good luck
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 1,486
