Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Question Closed
Replaced/Repaired cracked screen. Touchscreen not working...
I have disassembled and reassembled the new iPhone 4S display assembly. First off, the entire repair was so tedious with having to take apart the entire phone. I checked the new assembly thoroughly for cracks and bends or breaks in the cables and everything seems fine. I even rebooted the phone several times as well. Home button works fine. Volume buttons function, power button works. I just can't get any response from the touchscreen....
Anyone experiencing this issue/problem?
Worked so hard on this thing... So upset...
2 Comments
Hi, just did the display replacement on the 4S and everything went perfect including the startup BUT touchscreen potion doesn't work. I can't unlock phone because no where on screen does it sense my touch.
Did you ever find the issue with yours ?
Frankie5angels@mac.com
by
double check that the connector for the digitizer is seated properly and that you didn't tear the cable. a digitizer DOA is rare.
by
Add a comment
Chosen Solution
I would not be surprised if the digitizer is bad if you double checked all the connections. See if you can RMA it through who you purchased it.
Add a comment
You most likely sliced your ribbon cable while you were putting it threw that little slot in the metal frame its very easy to do.
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 1,478
