Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Questions View all
Solid Red Screen after digitizer replacment
After a digitizer replacement the LCD is solid red see photo. I tried another LCD same issue, so its clearly something on the board/connector but it was not like this before the repair.
Any help is appreciated.
https://www.dropbox.com/s/748sx9qb1gtp7o...
Add a comment
Chosen Solution
It's some sort of loose cable. I've had the exact same thing happen to me after my ipad2 experienced a slight drop on the floor.
(You can still see things on the screen, but the red pattern is still always sort of there in the background, right?)
Anyways, I read about this happening to other people online (try googling it) and the solution suggested one place, was to punch the back of the iPad.
I turned it around, gave it a good solid couple of whacks, and it fixed the problem, works fine now.
Add a comment
You most likely picked up a defective LCD. You can always try a hard reset, if it doesn't change anything this is probably the issue.
1 Comment:
The LCD was fine before the glass replacement. I tried a known good LCD and the iPad had the same issue. I still would like to know what causes this
by
Add a comment
Ha! worked punching in the back
Add a comment
check the chips and component around he LCD connector,,,,,use magnifying classes
Add a comment
Add your answer
Kyle will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,600
