13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
MacBook late 2008 unibody beeps but still works fine.
Hello,
I have a late 2008 macbook aluminum unibody that beeps 9 times every time i try to start it. 3 short 3 long and 3 short beeps every time. It goes through this cycle 2 or 3 times, until it gives up and boots. Once i log in, everything seems to work fine. The computer is not slow, and it stays cool. I already replaced the ram, and it still beeps. I've been reading for about 4 days now, and i can't find anyone with the same problem. Most of the people get three slow beeps, and it usually is the ram. The people i have found that get the same 9 beeps, are not able to boot into the OS. So i finally gave up and came here to try and get this thing working right. I don't think is anything mayor, because like i said before, once it boots, everything works just fine, as a matter of fact i'm typing this on it.
Score -1
1 Comment
This question was migrated from http://meta.ifixit.com/Answers.
by
Add a comment
Chosen Solution
You need to do a firmware restoration, here's info on it and how to do it:
http://support.apple.com/kb/HT2538?viewl...
Firmware restoration from CD in process. See About the Firmware Restoration CD (Intel-based Macs) for more details.
http://support.apple.com/kb/HT2213
Score 2
Add a comment
There might be a problem with the 'power on self-test' start up procedure. Something wrong with RAM.
Get more on the beeps: http://support.apple.com/kb/HT1547
Score 1
2 Comments:
Those beeps do not match the ones my macbook does. It usually goes beep, beep, beep, beeeep, beeeep, beeeep, beep, beep, beep.
by
I downloaded the Firmware Restoration CD 1.4. Burned it, and followed instructions step by step to restore the firmware, but it keeps ejecting the disk. It won't initiate the process. I never see the loading bar. This thing is driving me nuts. Thanks for all the help by the way.
by
Add a comment
Add your answer
Yarovy Arnedo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,754
