Repair information and guides for MacBook Pro models with 13" displays.
9742 Questions View all
Question Closed
Removing Display Glass from MacBook 13" Unibody 2009/2010
Hi I ordered a front display glass and tool kit. I have been heating thr glass for long but unable to remove the glass using suction cups. IT is not even slightly lifting. What to do. I dont have a heat gun, so I am using a regular Braun Hair Dryer. please guide urgently. My Mac is lying in disassembled condition !
Add a comment
Chosen Solution
Every job is easier when you use the proper tools. Go to a rental or home store and get a 1500 watt/120 volt Temperature Range: to 600+˚F heat gun. If you try to manhandle it you can damage parts you intend to reuse, necessitating spending more money.
If this answer was helpful please remember to return and mark it Accepted.
Add a comment
Most Helpful Answer
I did it with a normal hair dryer twice and it worked pretty well. I ordered the suction cups, but did not use them as I noticed I could not lift the glass.
At least I heated the glass to around 50 to 60 degrees celsius (you could touch it, but it was hard to) and used a guitar plec to lift the glass - a heat gun may be too much and you will burn the outer rubber.
While lifting the glass with a guitar plec you can insert another one between glass and cover and then go around the glass - be very careful - while constantly heating just the area you are going to lift with plec at next.
Regards, Stone
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 375
