Coolpix s4000 lens replacement
I can't seem to find a manual any where on line on how to replace a lens on a coolpix s4000 can you help please Thank you
I don't have a manual to point you to, but I know how most point-and-shoot cameras come apart. You usually remove the battery and memory card, take out all the screws from the outer case, and pull the front and rear case apart from each other. Once inside, you probably have to remove the LCD and LCD backing plate to gain access to the lens assembly screws.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 878
