Click Image To Zoom
iPod Touch Gen 4 Display Assembly
$69.95
Product code: IF146-000
Product Overview
The LCD and the digitizer are fused together and cannot be separated without breaking one of the two. You'll need to replace the whole assembly.
This includes the adhesive strips needed to install the new part.
Compatibility
Identify your iPod
  • All 4th Gen iPod Touch models
Product Details
$69.95 Black
Condition:
New
Warranty:
6 month warranty
$69.95 White
Condition:
New
Warranty:
6 month warranty
Add to Cart »
Compatibility
iPod Touch 4th Generation
32 GB
64 GB
8 GB
Stories
kevinblake's Story Photo #163697
My Problem
My daughter dropped her iPod Touch and cracked the front screen.
My Fix
The repair went well. Tedious and very very delicate, but successful.
My Advice
Please refer to the "Installing iPod Touch 4th Generation Front Panel Replacement" guide:
Step 1. I was a little hesitant with the heating of the adhesive. When I started prying, the screen cracked even more. I think that if I had gotten the adhesive hotter, the front panel would've come off easier. Later, I made sure that all the old adhesive was removed. At this point I did put more heat to it, and very carefully peeled the old adhesive strips up. This made it a lot easier to put down the new adhesive. Plus you don't want more than the thickness of one adhesive strip under the panel or it will not re-install flush.
Step 3 and 4 - As I lifted the front panel up from the bottom, the display data cable unplugged itself. This was OK, but watch that digitizer cable! That cannot be unplugged until much later.
Step 7 - WARNING - I broke a wire on this step. When prying under the bottom corner as shown in the guide, make sure you get between the steel mid plate and the "black box" (see my attached picture) The "black box" came up with the steel mid plate and the blue wire was broken at the corner of the PCB. Luckily I have access to some precise soldering equipment and I was able to splice a new wire in place.
Step 13 - Reattaching the display data cable is a pain because it is so short. My advice is to get a long tool (like a dental pick) that allows you to reach under the front panel while you hold it over the case. Use this tool to press down on the connector - Gently. Be patient.
Also, a very nice set of tweezers is highly, highly recommended.
The guide was great and if you follow it carefully, you should be successful. Good luck.
My Problem
My son decide take it outside without the protective case and he dropped it, breaking the entire display
My Fix
went great, broke one of the ipod pry tools though
My Advice
be very precise place the screws in order of where they were since they are different sizes.
My Problem
Sons itouch 4g screen was broken when another child swatted it out of his hand.
My Fix
First pass not so good. The white screen wouldn't clear on the hard reset. I thought that I mis wired something. Unfortunately I already attached the glue to seal it. While removing it I cracked the new lcd.
Luckily iFixIt sent me a replacement!!!!!
My Advice
Don't attach glue tape until the device powers up correctly.
If you get the white screen attach to itunes and restore it that will fix the problem!!!
My Problem
My daughter dropped her Ipod getting off the school bus and the front of it cracked.
My Fix
We bought the parts that we needed from ifixit.com and my husband repaired it.
My Advice
That it was less expensive to fix it then to go and buy a new ipod. I would recommend anyone to do this.
My Problem
I broke the screen.
My Fix
Followed a video tutorial.
My Advice
A second pair of hand help alot when putting the ipod back together.
My Problem
This is the second time I have dropped and cracked my 4th generation iPod's display.
My Fix
I repaired my iPod, both times by myself, with the aid of ifixit's guide. I do not have a lot of experience with home repairs (a couple of xbox x-clamp fixes) and the install guide was extremely helpful. The pictures and instructions are laid out very well and makes for a relatively easy repair.
My Advice
The first time I replaced the front panel I bought my display assembly off of ebay to save about $10. I do not recommend this. I didn't save that much money and the extra $10 was way worth it for how nicely everything came packaged. Just buy all of your supplies from ifixit.
My Problem
Drop = Shattered Screen
My Fix
It went ok. It was harder than I thought it would be.
My Advice
Have someone more experienced do it. Between the cost of the screen and tools, I could of had a number of websites fix it for less money and the outcome would have been better.
My Problem
Smashed screen on my sons iPod.
My Fix
The repair was easy with the help of the iFixit app that i installed on my iPhone 4. The pro tech base tool kit and dust blower are a great set of tools to use. With the word out with mates i've got them wanting to fix there stuff. Thanks for making it easy guys
My Advice
Maybe have a packet of fine tip paint maker pens in different colours to correspond with the screw colours in the fixit manuals to take out the guess work with the re-assemble of components.
My Problem
Shattered screen
My Fix
Fixed it, but not something we want to do again
My Advice
Photos don't exactly show you where to pry the camera loose. Be careful when doing it so you don't break it. Pictures online could be better. No I did not take any pictures, was trying not to break it and have to but a new iPod
My Problem
It was cracked when my wife dropped it in the gym.
My Fix
I followed the online repair and at first it seemed great. But the screen went out the second day, however your company was aware that some of the displays did this and sent me a second and it got here almost immediatly. Now it works works great. Will definately do bussiness you ifix it again!
My Advice
If its a first time repair, watch the online guide
