Click Image To Zoom
iPhone 5 Display Assembly (LCD, Front Panel/Digitizer Only)
$109.95
Product code: IF118-000
Apple Part #: 821-1451-06, 821-1452, 821-1451-06, 821-1452-06
Product Overview
Fix that broken screen!
  • This part does not come with the home button, front camera assembly, earpiece speaker, or the LCD shield plate.
  • You'll need to transfer these parts from your old display assembly to your new part.
  • We do sell the iPhone 5 Display Assembly with Home Button and Front Camera which includes all the smaller parts attached to the inside of the display assembly so you can skip transferring these parts.
  • You may also want to consider getting a nifty screen protector, so that your new iPhone display assembly can play nice with your keys.
Does not work in iPhone 5c or 5s.
Fix Kit contents:
Compatibility
Identify your iPhone
  • All iPhone 5 Models (Not iPhone 5s or 5c)
Product Details
$109.95 Fix Kit / Black
Condition:
New
Warranty:
6 month warranty
$109.95 Fix Kit / White
Condition:
New
Warranty:
6 month warranty
$104.95 Part Only / Black
Condition:
New
Warranty:
6 month warranty
Notes:
This option does not include tools.
$104.95 Part Only / White
Condition:
New
Warranty:
6 month warranty
Notes:
Add to Cart »
Install Videos
Compatibility
iPhone 5
16 GB
32 GB
64 GB
Stories
My Problem
Girlfriend dropped her iPhone 5 and cracked the screen and killed the digitizer.
My Fix
The directions were very clear and made the process simple enough. The hardest part was getting the home button contacts off. I used a bit of heat from a hair dryer, but I didn't want to burn anything, so I didn't use too much. I should have used more because I almost ripped off the contacts. After getting past that point, the rest was easy.
My Advice
If I had to do this again, I would either buy that heat roll thingy the girl used in the video, or I would take my time with a hair dryer to make sure I loosened up the adhesive more.
My Problem
Completely broken LCD glass on my Iphone even if still working.
My Fix
Not any problem with the repair
My Advice
1. Really touchy to remove the home button as it's hardly stuck but there are not any miracle solution. Be patient.
2. Make sure that the front camera is centered when mounting back.
My Problem
Mon iPhone était malencontreusement tombé dans un grand escalier en marbre, j'avais alors des morceaux d'écran qui se collait dans les doigts
My Fix
Réparation très facile mais le système pour lever l'écran est a revoir, une ventouse n'accroche pas sur un écran qui part en morceaux, elle les décolles. Mais ce problème régler la réparation était très simple, rapide et bien expliquée.
My Advice
Ne pas utiliser l'outils vert pour declipser l'écran, il faut utiliser son ongle pour faire levier des que la ventouse accroche un peux, sinon comme moi on finit par tout arracher
