Click Image To Zoom
PC2-5300 2 GB RAM Chip
$34.95
Product code: IF111-027-1
Product Overview
A fast 2 GB RAM Chip for laptops
  • RAM is the cheapest and most effective speed upgrade you can do for your computer
  • Faster file save/loading, web browsing, gaming, and more.
  • Check our list of Macs, or your manual to get the right chip style.
Compatibility
  • 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo MacBooks (Excludes MacBook Unibody)
  • 2.16, 2.2, 2.33, 2.4, 2.5 or 2.6 GHz (Models A1211/A1226/A1260) 15" MacBook Pros
  • 2.33, 2.4, 2.5, or 2.6 GHz (Models A1212/A1229/A1261) 17" MacBook Pros
  • 2 or 2.16 GHz 17" Intel iMacs
  • 2.16, 2.33, 2 (EMC 2133) or 2.4 (EMC 2133) GHz 20" Intel iMacs
  • 2.16, 2.33, 2.4 or 2.8 (EMC 2134) GHz 24" Intel iMacs
  • 1.83 or 2 GHz Core 2 Duo (Model A1176) Mac minis (3 GB maximum)
Product Details
  • Height: 1" (Low Profile)
  • Type: 200 pin, DDR-2, 667 MHz
  $34.95 New
Condition:
New
Warranty:
6 month warranty
Add to Cart »
16 Available
Quantity:
Compatibility
iMac Intel 17"
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
iMac Intel 24" EMC 2111
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz
2.8 GHz (EMC No. 2134)
Mac mini Model A1176
1.83 GHz (Core 2 Duo, Mid 2007)
2 GHz (Core 2 Duo, A1176)
MacBook Core 2 Duo
1.83 GHz (Core 2 Duo)
2 GHz (C2D, Late 2006)
2 GHz (C2D, Mid 2007)
2 GHz (Early 2009)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz (Core 2 Duo)
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Pro 15" Core 2 Duo Model A1211
2.33 GHz (Core 2 Duo)
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.4 GHz (Penryn)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.5 GHz (Penryn)
2.6 GHz (Penryn)
Stories
My Problem
The computer worked fine, but the hard drive was seven years old, about the time they stop working. So my friend and I replaced the hard drive and increased the memory.
My Fix
With your replacement parts, and your how to articles, it was very easy. My friend had already replaced the hard drives in his and his daughters iMacs, so he had no trouble guiding me through the procedure. We are both retired, and are thinking of doing this to make a little extra money, at least in the winter time.
My Advice
Make sure you have the right tools, have a good place to work on your repair, and most of all, DON'T BE AFRAID. The info on this site will get you through with no problems.
My Problem
I have an iMac thats about 6 years old and it needed a little boost. It only came with 1GB or memory and that just wasn't cutting it anymore with some of the larger, faster applications out today. With a quick look at my machines serial number, iFixit had the exact parts and guides I needed to give my computer the kick it needed (2x2GB RAM). Now I'm opening programs and flying through tabs and screens with ease! Thanks iFixit!
My Fix
I got my parts faster than I anticipated and the repair was a sweet breeze! with only one small philips panel screw on the underside of the monitor with a few faint picture instructions next to it, it wasn't exactly brain surgery. But it all went smoothly regardless! Popped one RAM chip out, stuck 2 brand new ones in easy as pie.
My Advice
If you can't seem to figure it out on your own, the iFixit website has all the explanation one would need to get you through this repair/upgrade.
My Problem
Couldn't run apps, forget flash and videos and even word processing...
5 year old macbook black was rheumatoid and exasperatingly slow
My Fix
New flash ssd
Doubled RAM
It's a new machine! Extra fast. Very very happy. Will use it for another 3-4 years I hope
My Advice
Online guides
My Problem
Two laptops had gotten very slow after updating to Maverick OS
My Fix
The upgrade went very well. The guides were excellent
My Advice
Follow instructions carefully. Especially pay attention to screw sizes.
My Problem
After the OS upgrade (10.7.5) the system begun requiring more memory (for no real reason actually) so I decided to buy more RAM to speed up the browser, email client, skype conversations and my dev VMs. The improvement allow me to keep my VMs on and talk on skype while browsing.
My Fix
Smooootly. I took less than 10 minute. Nothing exploded.
My Advice
Do it! Worth it definitely, though the biggest improvement will be updating the HD with an SSD.
My Problem
Increased the memory and replaced battery. Not able to find parts at the Apple store
My Fix
Perfect. The repair guide was really helpful
My Advice
No
My Problem
My Mac mini was running a little slow. Programs were taking time to boot up, and forget about running more than one application at a time.
My Fix
The guides were fantastic and easy to follow. I had never worked on a computer this small before, so I was unsure about it, but with the older machine, I figured it was worth the risk. Everything worked as advertised.
My Advice
When moving the Bluetooth and wireless antennas, be careful of the springs! The spring under the Bluetooth antenna shot up, off my desk when I moved the part. I lost the spring under my desk, but found it later.... At the end of my repair
My Problem
Upgrade vs. new
My Fix
Piece of cake...very straight forward. Formatting hard drive and setting up OS X was the only process that took some time
My Advice
Keep it up! Thanks
My Problem
I use my Macbook as a DVR for OTA television. I was going to buy a new Mac mini to replace it, but installing a bigger hard drive and more RAM saved money and extended the useful life of the Macbook.
My Fix
Extremely easy to do the replacements. The online guides were very helpful.
My Advice
Delete unused files and applications on your existing haddrive before using SuperDuper to make the new harddrive a bootable drive. You need to buy the USB drive case to hook up the harddrive to do the copying (it's part of the package that comes with a set of tools too).
My Problem
The usual - my Mac gets greedy for more RAM.
My Fix
Easy as swapping 2 slices of bread from the toaster - except with screwdriver.
My Advice
Don't use the Force..infact don't use any force. And I had no need to reset the PRAM.
