Click Image To Zoom
MacBook Heat Sink (Three-wall Connectors)
$29.95
Product code: IF186-010-1
Apple Part #: 922-7379
Product Overview
Includes thermal sensors.
Important: There are two different types of thermal sensor connectors on MacBook heat sinks. This heat sink has thermal sensor connectors that are flat. If your thermal sensor connectors are raised, this heat sink will not work in your computer. Reinstallation requires thermal paste.
Compatibility
Identify your Mac
  • 1.83 or 2 GHz Core Duo MacBooks
  • 1.83, 2, or 2.16 GHz Core 2 Duo MacBooks (excluding Santa Rosa)
Product Details
  $29.95
Condition:
Used, fully tested
Warranty:
6 month warranty
Add to Cart »
6 Available
Quantity:
Replacement Guides
MacBook Core 2 Duo
Difficulty: Difficult
MacBook Core Duo
Compatibility
MacBook Core 2 Duo
1.83 GHz (Core 2 Duo)
2 GHz (C2D, Late 2006)
2 GHz (C2D, Mid 2007)
2.16 GHz (Core 2 Duo)
MacBook Core Duo
1.83 GHz (Core Duo)
2 GHz (Core Duo)
Stories
My Problem
This macbook has been through many semesters of college, and was starting the second go around. The initial problem was that the bottom cover had many cracks and a piece broken out around the mag connector. Because of this, many arks and sparks happen while plugging into the charger and the battery would no longer indicate charging status. First part replaced was the original battery, (needed but no help). Macbook ran fine as long as it was plugged into the wall outlet. So I searched the web to try and find similar problems and solutions. The only one that came close to my failure was the replacement of the logic board. His only problem with this fix was that it only lasted about a week and failed again. I suspect that this person failed to adequately prep the heat sink pads and component with ArctiClean and create a good thermal connection with Arctic Silver Thermal Paste. So using your guide, I disassembled the Macbook and replaced the logic board. I also replaced the mag connector which actually could have been the only problem in the first place, but I had all the parts and just replace everything. Works great and my daughter believes I can fix anything.
My Fix
The repair went well. About 45 minutes to disassemble and about an hour to put it back together.
My Advice
Understand that the small connectors on the heat sink pull straight up, not out from the logic board. Maybe these had been very hot at one point, but were almost welded to the logic board connectors. Pulled the connectors off the pcb pads.
