MacBook Unibody (Model No. A1278) Upper Case (Backlit)
$249.95 up to $299.95
Product code: IF160-001
Apple Part #: 661-4944, 661-5856
Product Overview
Cases prevent wine bottles from getting lost, important documents from blowing away, and ground sausage meat from auctioning off family heirlooms on eBay. Safeguard your valuables with our MacBook Unibody upper case today.
Includes backlit keyboard, battery level indicator assembly, IR sensor, and battery connector cover.
NOTE: Some 2 GHz A1278 MacBook logic boards do not have the necessary socket installed to accept the keyboard backlight ribbon cable attached to the upper case. The second and third pictures show logic boards with and without the socket installed, respectively. If your logic board does not have the backlight ribbon cable socket installed, the keyboard will work but the keys will not light up.
If your logic board does not have the socket installed to accept the keyboard backlight ribbon cable and you are installing a backlit upper case, simply tuck the keyboard backlight ribbon cable out of the way when you reinstall the logic board into the upper case.
Compatibility
Identify your Mac
  • 2 or 2.4 GHz Unibody (Model No. A1278) 13" MacBooks
Product Details
$299.95 A-Stock
Condition:
Used, fully tested
Warranty:
6 month warranty
$249.95 B-Stock
Condition:
Used, fully tested
Warranty:
6 month warranty
Add to Cart »
Compatibility
MacBook Unibody Model A1278
2 GHz (A1278)
2.4 GHz (A1278)
