MacBook 13" Core Duo Parts
When it comes to the MacBook, big things really can come in small packages. This bulldog offers an exceptional amount of processor power while holding on to a petite look and feel. This model is the easiest of the Intel Macs to upgrade RAM and hard drive capacity, and its plastic encasement is great for wireless reception!
The MacBook 13" Core Duo can be easily upgraded to a total of 2 GB of memory using two 1 GB RAM chips, and a 500 GB 7200 RPM SATA hard drive will give you plenty of storage. You can upgrade to the Santa Rosa/Penryn Upper Case, featuring a new keyboard layout (including iTunes controls)! The 8x SuperDrive is the fastest optical drive for this model and will make creating DVDs a whiz. Have you ever been caught sleeping while waiting for your file to transfer over slow wireless network? We can wipe away that unnecessary snooze-fest with the Airport Extreme 802.11n Card upgrade.
There is one main variation within this model. The heat sink thermal sensors may have three-wall or four-wall connectors. This affects the heat sink and logic board. See photos and part descriptions on the three-wall or four-wall heat sinks for information on determining which version you have.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)
SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM.
See full description
$219.95
MacBook Core Duo 2 GHz Logic Board
2 GHz Motherboard / Ports: Mini DVI Video Out, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out
$399.95
MacBook 13.3" Core Duo Display Assembly
1280x800 LCD / 13.3"
$299.95–$399.95
MacBook Core Duo 1.83 GHz Logic Board
1.83 GHz Motherboard / Ports: Mini DVI Video Out, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out
$349.95
750 GB Hybrid Seagate SATA Hard Drive
SSD speeds from the Momentus XT Hybrid Drive.
$249.95
1 TB 5400 RPM Samsung SATA Hard Drive (New)
SATA interface for Intel Macs / Samsung / 2.5" wide x 9.5mm tall / 1 TB Unformatted / 5400 RPM
$249.95
120 GB Solid State Drive
SATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 120 GB Unformatted / SSD
$229.95
750 GB 7200 RPM SATA Hard Drive
SATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM
$209.95
MacBook 13.3" LCD Panel
LCD without the display bezels, hinges, hinge mount or cables / 1280x800 LCD / 13.3"
$149.95–$199.95
MacBook 8x SuperDrive (Used)
DVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 8x DVD-R write, 8x DVD+R write, 4x DVD-RW write, 24x CD-R write, 10x CD-RW write
$199.95
