MacBook 13" Core 2 Duo Late 2006 Parts
Good became even better with the addition of Intel's Core 2 Duo processor!
The MacBook 13" Core 2 Duo (Late 2006) can be upgraded to a total of 3 GB of memory using a 2 GB RAM chip and a 1 GB RAM chip. The 500 GB 7200 RPM SATA hard drive will give you plenty of storage. The 8x SuperDrive is the fastest optical drive for this model and will make creating DVDs a whiz. You can also upgrade the upper case to the Penryn/Santa Rosa version with the new keyboard layout (including iTunes controls)!
There is one main variation within this model. Your machine may be a Energy Star-equipped or non-Energy star version. This affects the battery connector and logic board. See photos and part descriptions on the non-Energy Star or Energy Star battery connector/sleep sensors for information on determining which version you have.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
Showing products 1 - 10 of 76
| | 750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM. | $219.95 |
| | MacBook Core 2 Duo 2.16 GHz (non-Energy Star) Logic Board2.16 GHz Motherboard / Ports: Mini DVI Video Out, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out | $499.95 |
| | MacBook 13.3" Core 2 Duo Display Assembly1280x800 LCD / 13.3" | $299.95–$499.95 |
| | MacBook Core 2 Duo 2 GHz (non-Energy Star) Logic Board2 GHz Motherboard / Ports: Mini DVI Video Out, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out | $399.95 |
| | MacBook Core 2 Duo 1.83 GHz Logic Board1.83 GHz Motherboard / Ports: Mini DVI Video Out, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out | $349.95 |
| | 750 GB Hybrid Seagate SATA Hard DriveSSD speeds from the Momentus XT Hybrid Drive. | $249.95 |
| | 1 TB 5400 RPM Samsung SATA Hard Drive (New)SATA interface for Intel Macs / Samsung / 2.5" wide x 9.5mm tall / 1 TB Unformatted / 5400 RPM | $249.95 |
| | 120 GB Solid State DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 120 GB Unformatted / SSD | $229.95 |
| | 750 GB 7200 RPM SATA Hard DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM | $209.95 |
| | MacBook 13.3" LCD PanelLCD without the display bezels, hinges, hinge mount or cables / 1280x800 LCD / 13.3" | $149.95–$199.95 |
