Click Image To Zoom
iMac Intel 20" 2/2.4 (EMC No. 2133) GHz Power Supply
$139.95
Product code: IF168-004-1
Apple Part #: 661-4433
Product Overview
If you receive one of these power supplies that appears different from the product picture, it is still compatible, just a slightly different physical model.
Compatibility
Identify your Mac
  • 2 (EMC No. 2133) and 2.4 (EMC No. 2133) GHz 20" Intel iMacs
Product Details
  $139.95 New
Condition:
New
Warranty:
6 month warranty
Add to Cart »
9 Available
Quantity:
Compatibility
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
Stories
My Problem
My power supply went kaput and my iMac would not turn on! I found "iFixit" through a search on the web. The repair was more than cost efficient.
My Fix
iFixit showed me what to look for and exactly how to disassemble my iMac and what part was needed to repair it. I ordered the part and it was shipped. The very same day the part was delivered, it was installed. My iMac was reassembled and it worked!
My Advice
I was content to shelve my old machine since I just purchased a Mac Book Pro. Thanks to "iFixit", I have my iMac back and running for $149. The access to the right parts are a plus. The technical information is a must. Never be too afraid to try new things. Thanks! iFixit!
My Problem
Two weeks prior to the IMac failing completely I noticed that the PC shut down and couldn't be turned on. I found some help on the internet that allowed me to reset the power supply. Pull the cord, wait 10 seconds, hold in the power button for 5 to 10 seconds, release, then plug in and power up normally.
The power supply failure occurred two weeks later so I ordered the power supply through ifixit and followed the procedures to replace it.
My Fix
The ifixit steps were very clear. I used a bath tub mat with suction cups to get the outer glass off. The rest of the procedure went well. I did need an extra hand to hold the screen up while I disconnected the four connectors. The hardest part was making sure the glass was clean when I put it back together.
My Advice
Be careful but don't be afraid of replacing the power supply. Next time, I would use individual torx screw drivers instead of the multiple tool torx set. The short multitool torx set is a bit awkward and I had to be careful that it didn't slip and hit the glass.
