Click Image To Zoom
Customers also bought
PC2-5300 4 GB RAM Chip
$119.95
MacBook 13.3" LCD Panel
$149.95
Metal Spudger Set
$7.95
Phillips #00 Screwdriver
$4.95
Installation Guides
iMac Intel 17"
Difficulty: Easy
iMac Intel 20" EMC 2105 and 2118
Difficulty: Easy
iMac Intel 20" EMC 2133 and 2210
Difficulty: Easy
iMac Intel 24" EMC 2111
Difficulty: Easy
Mac mini Model A1176
Difficulty: Moderate
MacBook Core 2 Duo
Difficulty: Easy
MacBook Pro 15" Core 2 Duo Model A1211
Difficulty: Easy
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
Difficulty: Easy
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
Difficulty: Easy
PowerBook G4 Aluminum 15" 1.67 GHz
Difficulty: Easy
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res)
Difficulty: Easy
Compatibility
| iMac Intel 17" |
| iMac Intel 20" EMC 2105 and 2118 |
| iMac Intel 20" EMC 2133 and 2210 |
| iMac Intel 24" EMC 2111 |
| iMac Intel 24" EMC 2134 and 2211 |
| Mac mini Model A1176 |
| MacBook Core 2 Duo |
| MacBook Pro 15" Core 2 Duo Model A1211 |
| MacBook Pro 15" Core 2 Duo Models A1226 and A1260 |
| MacBook Pro 17" Models A1151 A1212 A1229 and A1261 |
Stories
My Problem
I neded more ram becaus i am vorking a lot with diferent programs open
My Fix
I received the ram in my mailbox at only 6 days after i ordered from you :-)
The repair was fixed after 2 minutes :-))
My Advice
Only from your website
My Problem
I needed more GB Ram to be able to get more apps for my Mac.
My Fix
Great! The directions were very easy and understandable.
My Advice
NO
My Problem
It's 2012 - 2 gigs of RAM just isnt enough. So I did the best I could and upped my computer to its max of 3 gigs.
My hard drive wasn't showing any signs of failure, but since I was doing some computer surgery, I figured it would be a good time to go from a 120 gig 5400 rpm to a 500 gig 7200 rpm hybrid drive.
My fans - well, they could be heard from down the street they became so noisy and inefficient.
My Fix
It took me about one hour to replace everything. With all of the tools I needed and the detailed guides, it couldn't have gone smoother!
My Advice
Repairs on a laptop - not so tough when you have detailed instructions on what you're looking to do!
My Problem
for inst. af lion
My Fix
OK
My Advice
Hurtig ekspedition
My Problem
Needed to upgrade my wife's old MacBook to Lion and she only had 512MB of RAM which didn't meet minimum requirements.
My Fix
Super smooth thanks to the ifixit guide. I'm not a mac guy but ifixit's guide made it extremely easy to identify which RAM chip I needed to purchase and how to install it. Also, ifixit sold the RAM chip for 50% cheaper than the Mac store in downtown San Luis Obispo.
My Advice
If I knew the repair experience would be this easy I would have done it a while ago.
My Problem
The 320GB internal hard drive on my 24" iMac Intel died. I replaced it with a 1TB drive and, while at it, maxed out the RAM to 4GB. I used the 20" iMac repair guide which was very close. It is not the first time I used iFixit guides. I also fixed an old MacBook a few years back. I love you guys!
My Fix
It went peachy. Everything worked beautifully when I was done.
My Advice
Follow the instructions on the repair guide and all will be fine
My Problem
I wanted to install LION but only had 1GB RAM in my older Macs.
My Fix
Easy! Gentle but firm pressure seated the new 2GB cards and now each computer enjoys 4GB. Installed LION with no issues. Now learning how to use the new features.
My Advice
Your guides offered just enough. The pictures exactly matched my Macs and gave me the confidence for a DIY. I should be able to stretch these Macs at least to the next major OS release.
My Problem
I found my macbook increasingly inefficient when dealing with editing programs this was beginning to hamper my work.
My Fix
Easy-peezy... half an hour or so and it was all installed. I also brought a cheap HD enclosure to put the old HD in. I then plugged this in to the mac, it automatically rebooted from this and I was able to reformat the new internal HD and transfer all the data using Superduer.
My Advice
Compared to buying a new mac this upgrade saved me loads of dosh-not to mention the resources used in making a shiny new product. We shall see how it holds out but for now I am happy with my lighting fast machine. Make do and Mend- that is the watchword.
My Problem
I was trying to edit video using the Camtasia program. My computers' installed 2GB of RAM was way too slow - lagging and freezing - to allow practical use of the software. So, I opted to expand my MacBookPro #A1260 to 6GB of RAM.
My Fix
Easy... After you remove the RAM shield the computer practically offers the installed RAM to you.
I just used the pointed ends of a couple spudgers to move the metal clips holding down each RAM chip. The assembly holding the chip is spring-loaded and flips forward, allowing you to remove or install memory.
I removed two 1GB RAM chips and installed a 2GB chip and a 6GB chip. They worked upon reboot without any problems.
My Advice
None what-so-ever... installation guide was perfect.
My Problem
I asked the Apple rep at a store how much memory I could put on this laptop. The answer was 2GB. I'm developing numerical models that require lots of RAM, and the O.S. takes about 1GB. So I was thinking about doing a laptop upgrade.
My Fix
The kit I got for doing the HD replacement was useful, as the screws are very small. I experienced absolutely NO difficulty with this "operation".
My Advice
The instructions were clear. There isn't any more advice I could give.
Related Questions
1 Answer 0 Score |
RAM upgrade to 5GB possible? |
2 Answers 0 Score |
How much ram can I add for 2 ghz core 2 Duo |
3 Answers 1 Score |
Can I upgrade from 2Gb to 3Gb RAM |
