Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Questions View all
Why does Mac OS X fail to install?
21.5 inch Mid 2011 iMac
In an effort to make the computer brand new, I decided to reinstall Lion. After a quick Google, I erased the hard drive using Disk Utility & restarted in Recovery Mode. I clicked the "Reinstall Mac OS X" option and agreed to the terms, and chose destination to install. It then downloaded a fresh copy of Lion and rebooted to the Mac OS X Installer. Less than a minute into the installation an error pops up:
"Mac OS X could not be installed on you computer.
Mac OS X can't be installed on the disk Macintosh HD, because a recovery system can't be created. Visit http://www.apple.com/support/no-recovery to learn more.
Click Restart to restart you computer and try installing again."
I've retried at least a dozen times with the same results. I know there is a solution out there, but it has evaded me for the past two weeks. Any advice would be appreciated more than you can imagine.
Score 1
Add a comment
Chosen Solution
Try installing a 10.6 system from your original system installation disk, do the updates to 10.6.8 then install Lion and update again.
Score 3
1 Comment:
Check with Disk Utilities to see if you've formatted the drive GUID. Still failing? Do a reformat using the "write zeros" option to map out any bad blocks. This failing, your machine may still be under warranty, get a replacement drive. You are using the original hard drive, correct?
by
Add a comment
I had this same issue. I fixed it by booting into internet recovery mode (Cmd+Option+R) and then opening Terminal from the file menu and using diskutil to delete the highest level Logical Volume Group as shown here Erasing a FileVault 2-encrypted Volume -- Then closed Terminal and opened the Disk Utility GUI tool. Created a new partition. Closed Disk Utility and then ran the install again and it worked!
Score 1
1 Comment:
Matt good find!
by
Add a comment
It sounds like your boot table is corrupted. Have you run Disk Utility and reformatted the drive with the Mac OS Extended journaled format?
2 Comments:
When i try to partition the hard drive, it fails with the error: Couldn't unmount disk.
by
You may try a third party format tool to see if it can fix the drive otherwise it sounds like the disk is bad
by
Add a comment
Every time I hold cmd+Option+R it tries to do an internet recover and does the whole process again
Add a comment
Add your answer
Bastian will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 18
All Time: 15,099
