Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Questions View all
Question Closed
Change HD with Time Capsuel on
Hello,
I have a dead Time Capsule 2 gen. with a 1TB HD. I would like to change my 320GB HD of my iMac with the one from the Time Capsule.
Does anyone knows if this Time Capsule HD is compatible with my iMac 20'' mid 2007?
Thanks to all for your help.
1 Comment
Thank you all for your helpful answers.
I think Machead3 is totally right about the feasibility of this HHDD. May be it is not a good idea to change it by the one on the time Maching because I could have problems in the future.
My time capsule copy is now already in oder external HD. No mater about to lost my backup copies.
Thanks again for the help.
Jalandiso
by
Add a comment
Chosen Solution
By default the Time Capsule drive does not have the Mac OS installed on it. Be careful you don't erase your backup files if you use Time Machine when you install the OS on to it.
In addition the Time Machine backup files won't be accessible if you forgot your Time Machine user account and password (stored in the current iMac HD system files).
If you do care about getting to your saved files on the Time Capsule it maybe better getting a new external HD case to put the Time Capsule HD into so you can access it via Firewire (best) or USB cable Vs swapping out the your iMac systems HD drive.
With the external case you can also upgrade your iMac system HD with a bigger HD with a new HD, by using the migration assistant to image your current HD onto the new HD held in the external case. Then once you swap your iMac system drive with the new HD you can then take the Time Capsule HD out and put it into the new external case and continue using it as a backup. As you made a full image of your current iMac HD you won't have lost your Time Machine user account or password that is stored in your iMac system files his way.
Score 2
Add a comment
Most Helpful Answer
Many of these early Time Capsule drives are highly unreliable, ''especially the the Hitachi DEATHstar''. The Western Digital & Seagate drives less so. The SATA drives are compatible.
If this Answer is helpful please remember to return and mark it Accepted.
Score 2
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 565
